Introdução
Keyboard may need replacing for several reasons ranging from spilling something on your keyboard to mulitple keys not working properly. You will need a new standard replacement keyboard for Lenovo S20-30 to continue the replacement. Keyboards costs around $22-$50. This guide shows step by step how to replace your Lenovo S20-30 keyboard. Make sure to carefully read the steps and keep track of parts dissassembled so they are not lost.
O que você precisa
Remove the two front rubber feet using a long metal spudger.
Use your Phillips #0 screwdriver to remove the two M2.5 x 5mm flat-head screws located underneath the pads.
3 outras pessoas executaram este guia.
