Ir para o conteúdo principal
Lenovo S20-30 Keyboard Replacement
O que você precisa
  1. Lenovo S20-30 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Flip the Lenovo S20-30 over so that the bottom panel is facing upward.
  2. Lenovo S20-30 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the manual battery latch to the unlock position, so that the red is showing.
  3. Lenovo S20-30 Keyboard Replacement: passo 3, imagem 1 %32 Lenovo S20-30 Keyboard Replacement: passo 3, imagem 2 %32
    • Slide and hold the spring-loaded battery latch on the other side (right) while sliding the battery out of the computer.
    • Grab new Lenovo S20-30 battery for replacement.
  4. Lenovo S20-30 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32 Lenovo S20-30 Keyboard Replacement, Keyboard: passo 4, imagem 2 %32 Lenovo S20-30 Keyboard Replacement, Keyboard: passo 4, imagem 3 %32
    • Remove the two front rubber feet using a long metal spudger.
    • Use your Phillips #0 screwdriver to remove the two M2.5 x 5mm flat-head screws located underneath the pads.
  5. Lenovo S20-30 Keyboard Replacement: passo 5, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove the nine M2 x 4mm flat head screws located on the outer edges on the back of the laptop.
    • Make sure to keep these screws separated from future screws that will be disassembled throughout this process.
  6. Lenovo S20-30 Keyboard Replacement: passo 6, imagem 1 %32 Lenovo S20-30 Keyboard Replacement: passo 6, imagem 2 %32
    • Use the long metal spudger to pry open the bottom half of the laptop.
    • Gently lift the cover off to reveal the motherboard.
  7. Lenovo S20-30 Keyboard Replacement: passo 7, imagem 1 %32 Lenovo S20-30 Keyboard Replacement: passo 7, imagem 2 %32
    • Remove the four M2 x 3mm flat-head screw using a Phillips #000 screwdriver.
  8. Lenovo S20-30 Keyboard Replacement: passo 8, imagem 1 %32 Lenovo S20-30 Keyboard Replacement: passo 8, imagem 2 %32
    • Flip over laptop and open the lid to have access to the keyboard.
    • Use a plastic opening tool to pry apart the keyboard.
  9. Lenovo S20-30 Keyboard Replacement: passo 9, imagem 1 %32 Lenovo S20-30 Keyboard Replacement: passo 9, imagem 2 %32 Lenovo S20-30 Keyboard Replacement: passo 9, imagem 3 %32
    • A connector is attached to the keyboard.
    • Remove it by gently pulling it outward.
  10. Lenovo S20-30 Keyboard Replacement: passo 10, imagem 1 %32
    • Grab replacement keyboard to insert back into place.
Conclusão
3 outras pessoas executaram este guia.
ILEANISSE SOTO
Membro desde: 10/01/18
187 Reputação
Autoria de 1 guia
Equipe
Um comentário
where can i find a replacement keyboard/ or what model # do i need?
ed paz - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 1,222
