Introdução
This will show you how to remove the keyboard on the Lenovo N23 Yoga Chromebook
  1. Flip the computer over. Remove the 9 screws surrounding the edges of the computer. Remove the single screw near the center of the computer.
    • Flip the computer over.
    • Remove the 9 screws surrounding the edges of the computer.
    • Remove the single screw near the center of the computer.
  2. Use a smaller plastic panel popping tool to begin (if you have one). You may increase to a larger size as you go (if you have one)
    • Use a smaller plastic panel popping tool to begin (if you have one). You may increase to a larger size as you go (if you have one)
    • Slowly work your way around the edges of the computer.
    • Closer to the screen the clips will be sturdier, use a little more force but still be cautious.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. On the main board, lift up on the black tabs of the connectors that are connected to the ribbons.
    • On the main board, lift up on the black tabs of the connectors that are connected to the ribbons.
    • Remove the ribbon connectors gently from the main board.
  5. The keyboard should be free and disconnected from the rest of the computer.
    • The keyboard should be free and disconnected from the rest of the computer.
Conclusão
2 outras pessoas concluíram este guia.
Drew Canada
998 reputação
4 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 38
Todo: 239
