Ir para o conteúdo principal
Lenovo N22 Chromebook Wireless Card Replacement
O que você precisa
  1. Lenovo N22 Chromebook Wireless Card Replacement, Keyboard: passo 1, imagem 1 %32 Lenovo N22 Chromebook Wireless Card Replacement, Keyboard: passo 1, imagem 2 %32 Lenovo N22 Chromebook Wireless Card Replacement, Keyboard: passo 1, imagem 3 %32
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Wireless Card Replacement: passo 2, imagem 1 %32 Lenovo N22 Chromebook Wireless Card Replacement: passo 2, imagem 2 %32 Lenovo N22 Chromebook Wireless Card Replacement: passo 2, imagem 3 %32
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Wireless Card Replacement: passo 3, imagem 1 %32 Lenovo N22 Chromebook Wireless Card Replacement: passo 3, imagem 2 %32
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Wireless Card Replacement: passo 4, imagem 1 %32
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
  5. Lenovo N22 Chromebook Wireless Card Replacement, Wireless Card: passo 5, imagem 1 %32 Lenovo N22 Chromebook Wireless Card Replacement, Wireless Card: passo 5, imagem 2 %32
    • Use a Philips #1 screwdriver to remove the 3.6 mm screw from the back panel.
  6. Lenovo N22 Chromebook Wireless Card Replacement: passo 6, imagem 1 %32
    • Gently slide the wireless card to the right to remove it from the standard socket on the motherboard.
  7. Lenovo N22 Chromebook Wireless Card Replacement: passo 7, imagem 1 %32 Lenovo N22 Chromebook Wireless Card Replacement: passo 7, imagem 2 %32
    • Grab the black and white wires as close to the antenna cable connectors as possible.
    • Gently pull the black and white wires away from the antenna cable connectors on the wireless card.
    • When reinstalling, place the wires on the antenna cable connectors and gently press straight down. The wires should snap back into the connector.
    • When reinstalling, make sure that the white wire and the black wire are put back in their original connectors.
Conclusão
Megan Louie
Membro desde: 04/26/17
323 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S21-G1, Livingston Spring 2017 Membro de Cal Poly, Team S21-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G1
Membros da 4
Autoria de 14 guias
Um comentário
Very well explained and photographed. My first attempt at a laptop repair and this guide made it possible.
Thanks!
Jeff Koskela - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 31
Duração total: 3,952
