Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
This guide will explain how to remove the battery from the Chromebook. The battery may need to be removed if there are issues with the battery staying charged or with the device powering on.
O que você precisa
Flip the Chromebook so that the bottom is facing up.
Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
Use a spudger to remove each of the 4 rubber feet.
Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
Flip the Chromebook back over and open the screen.
Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
Separate the battery cable from the motherboard by wedging the edge of a plastic opening tool between the black cable connector and the silver socket on the motherboard.
Pull the battery cable straight towards you, away from the silver socket.
10 outras pessoas executaram este guia.
4 comentários
amazing!! thank you
thanks I needed to take the bottom off so I can take a certain screw
cuck trentxluka
That's way too much just to take the battery out. it was helpful having these steps. Thank you
