Introdução
To replace the trackpad or keyboard of the Lenovo N21 Chromebook, the whole panel including both parts will need to be replaced.
If you are trying to replace other parts within the Lenovo N21 Chromebook, the trackpad and keyboard panel will have to be removed from the bottom housing in order to access these interior parts.
O que você precisa
Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
4 outras pessoas executaram este guia.
