Introdução
Once the keyboard and touch pad have been removed, the battery can be easily replaced by removing three screws and a connection cable.
O que você precisa
Use a screwdriver to remove the six 5.0mm Phillips screws from the bottom housing of the Chromebook.
Disconnect the white charging cable connectors by pulling straight down on the connector.
7 outras pessoas executaram este guia.
