Ir para o conteúdo principal
Lenovo N20p Chromebook WLAN & Bluetooth Replacement
O que você precisa
  1. Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Keyboard: passo 1, imagem 1 %32 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Keyboard: passo 1, imagem 2 %32
    • Power down the Chromebook before starting any repair.
    • Remove the two 3.5 mm Phillips #0 screws using a screwdriver.
    • It is only necessary to remove these two screws to complete this step.
  2. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 2, imagem 1 %32 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 2, imagem 2 %32
    • Use the hook of the metal spudger to carefully lift up the keyboard.
    • Lift the keyboard carefully. If you lift too quickly, it might break the two cables that connect the keyboard to the motherboard.
  3. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 3, imagem 1 %32 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 3, imagem 2 %32 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 3, imagem 3 %32
    • Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
    • You will now be able to replace the keyboard.
  4. Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Battery: passo 4, imagem 1 %32 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Battery: passo 4, imagem 2 %32 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, Battery: passo 4, imagem 3 %32
    • Remove the two rubber feet of the back of the Chromebook using a metal spudger.
    • Remove six bottom 3.5 mm Phillips #0 screws and two top 5 mm Phillips #1 screws.
  5. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 5, imagem 1 %32
    • Remove all nine 3.5 mm Phillips #00 screws using a screwdriver.
  6. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 6, imagem 1 %32 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 6, imagem 2 %32
    • Disconnect the battery cable from the motherboard.
    • Disconnect the touch-pad cable from the motherboard.
  7. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 7, imagem 1 %32 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 7, imagem 2 %32
    • Use the metal spudger along the seam between the keyboard and the bottom of the Chromebook to lift up and remove the palm rest assembly.
    • It is normal for it to click loudly when it is released. Corner tags will be harder to release than other tags and will make a loud sound.
  8. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 8, imagem 1 %32 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 8, imagem 2 %32 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 8, imagem 3 %32
    • Disconnect the USB cable from the motherboard by pulling the blue tab out of the cable.
    • Remove all five 3.0 mm Phillips #00 screws which connect the battery and motherboard.
  9. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 9, imagem 1 %32 Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 9, imagem 2 %32
    • Remove the battery.
    • It is helpful to lift and hold the battery as shown.
  10. Lenovo N20p Chromebook WLAN & Bluetooth Replacement, WLAN & Bluetooth: passo 10, imagem 1 %32 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, WLAN & Bluetooth: passo 10, imagem 2 %32 Lenovo N20p Chromebook WLAN & Bluetooth Replacement, WLAN & Bluetooth: passo 10, imagem 3 %32
    • Disconnect the white and black cables from the WLAN & Bluetooth combo.
    • Remove the 2 mm Phillips #1 screw.
    • Lift and pull the WLAN & Bluetooth in the direction shown.
  11. Lenovo N20p Chromebook WLAN & Bluetooth Replacement: passo 11, imagem 1 %32
    • You will now be able to replace the WLAN & Bluetooth combo module.
Conclusão
Shihao Cao
Membro desde: 07/12/18
497 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S1-G2, Cardinal Summer 2018 Membro de UW Tacoma, Team S1-G2, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G2
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 218
