Ir para o conteúdo principal
Lenovo N20p Chromebook Keyboard Replacement
O que você precisa
  1. Lenovo N20p Chromebook Keyboard Replacement, Keyboard: passo 1, imagem 1 %32 Lenovo N20p Chromebook Keyboard Replacement, Keyboard: passo 1, imagem 2 %32
    • Power down the Chromebook before starting any repair.
    • Remove the two 3.5 mm Phillips #0 screws using a screwdriver.
    • It is only necessary to remove these two screws to complete this step.
  2. Lenovo N20p Chromebook Keyboard Replacement: passo 2, imagem 1 %32 Lenovo N20p Chromebook Keyboard Replacement: passo 2, imagem 2 %32
    • Use the hook of the metal spudger to carefully lift up the keyboard.
    • Lift the keyboard carefully. If you lift too quickly, it might break the two cables that connect the keyboard to the motherboard.
  3. Lenovo N20p Chromebook Keyboard Replacement: passo 3, imagem 1 %32 Lenovo N20p Chromebook Keyboard Replacement: passo 3, imagem 2 %32 Lenovo N20p Chromebook Keyboard Replacement: passo 3, imagem 3 %32
    • Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
    • You will now be able to replace the keyboard.
Conclusão
Shihao Cao
Membro desde: 07/12/18
497 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team S1-G2, Cardinal Summer 2018 Membro de UW Tacoma, Team S1-G2, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G2
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 287
