Ir para o conteúdo principal
Lenovo Miix 2 Battery Replacement
O que você precisa
  1. Lenovo Miix 2 Battery Replacement, Battery: passo 1, imagem 1 %32 Lenovo Miix 2 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Battery Replacement: passo 2, imagem 1 %32 Lenovo Miix 2 Battery Replacement: passo 2, imagem 2 %32
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Battery Replacement: passo 3, imagem 1 %32 Lenovo Miix 2 Battery Replacement: passo 3, imagem 2 %32
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Battery Replacement: passo 4, imagem 1 %32 Lenovo Miix 2 Battery Replacement: passo 4, imagem 2 %32
    • Remove the battery by prying up with your fingers or a plastic opening tool.
Conclusão
3 outras pessoas executaram este guia.
Nicolas Jones
Membro desde: 04/14/15
395 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 5-8, Maness Spring 2015 Membro de Cal Poly, Team 5-8, Maness Spring 2015
CPSU-MANESS-S15S5G8
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 25
Duração total: 8,896
