Ir para o conteúdo principal
Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement
O que você precisa
  1. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement, W-Fi Card: passo 1, imagem 1 %32 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement, W-Fi Card: passo 1, imagem 2 %32 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement, W-Fi Card: passo 1, imagem 3 %32
    • Using the Phillips #00 screws, remove 13 screws from the backside of the laptop.
    • Five 2x1/2 screws.
    • Eight 1x1/2 screws.
  2. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: passo 2, imagem 1 %32
    • Pry open the back cover open with a plastic opening tool.
  3. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: passo 3, imagem 1 %32 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: passo 3, imagem 2 %32
    • Carefully remove the taped on paper under the fans.
  4. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: passo 4, imagem 1 %32 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: passo 4, imagem 2 %32 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: passo 4, imagem 3 %32
    • Remove the four screws that are holding the battery down using a Phillips #00 screwdriver.
    • Disconnect and remove the battery from the device.
  5. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: passo 5, imagem 1 %32 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: passo 5, imagem 2 %32 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: passo 5, imagem 3 %32
    • Using a plastic opening tool, carefully disconnect the two cables connected to the Wi-Fi card.
  6. Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: passo 6, imagem 1 %32 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: passo 6, imagem 2 %32 Lenovo Legion Y7000P-1060 Wi-Fi Card Replacement: passo 6, imagem 3 %32
    • Using the Phillips #00 screwdriver, remove the screw holding the Wi-Fi card to the device.
    • Remove the Wi-Fi Card from the device.
Conclusão
Lawrence Lam
Membro desde: 10/20/20
204 Reputação
Autoria de 1 guia
Equipe
3 comentários
Thanks for the guide Lawrence, can I ask what card you replaced the stock one with?
mkrnblack - Responder
I reccomend using the Wireless AC 8265 with bluetooth. There is the one I bought:
Intel Dual Band Wireless-Ac 8265... https://www.amazon.com/dp/B01MZA1AB2?ref...
Hope it goes well for you, it should fix all the ping spikes and unstable internet from the stock lenovo wifi chip.
Lawrence Lam -
Thanks for the recommendation I originally went with the 9560.NGWG.NV but It was not an improvement, in fact it might be worse. So I will try the 8265.
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 23
Duração total: 1,348
