Ir para o conteúdo principal
Lenovo Legion Y530-15ICH USB Port Replacement
O que você precisa
  1. Lenovo Legion Y530-15ICH USB Port Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH USB Port Replacement: passo 2, imagem 1 %32 Lenovo Legion Y530-15ICH USB Port Replacement: passo 2, imagem 2 %32
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: passo 3, imagem 1 %32 Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: passo 3, imagem 2 %32
    • Remove the ribbon cable connecting the USB port to the motherboard, located adjacent to the fan unit.
    • Using a JIS #1 screwdriver, remove the two screws securing the USB port to the module.
  4. Lenovo Legion Y530-15ICH USB Port Replacement: passo 4, imagem 1 %32
    • Gently disconnect the single ribbon cable with your fingers.
    • Remove the USB port from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 819
