Ir para o conteúdo principal
Lenovo Legion Y530-15ICH Speaker Replacement
O que você precisa
  1. Lenovo Legion Y530-15ICH Speaker  Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH Speaker  Replacement: passo 2, imagem 1 %32 Lenovo Legion Y530-15ICH Speaker  Replacement: passo 2, imagem 2 %32
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Speaker  Replacement, Battery: passo 3, imagem 1 %32
    • Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
  4. Lenovo Legion Y530-15ICH Speaker  Replacement: passo 4, imagem 1 %32 Lenovo Legion Y530-15ICH Speaker  Replacement: passo 4, imagem 2 %32
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Now you can safely remove the battery.
  5. Lenovo Legion Y530-15ICH Speaker  Replacement, Speaker: passo 5, imagem 1 %32
    • Remove the five screws using the Phillips #0 screwdriver.
  6. Lenovo Legion Y530-15ICH Speaker  Replacement: passo 6, imagem 1 %32
    • Gently peel up the copper adhesive.
  7. Lenovo Legion Y530-15ICH Speaker  Replacement: passo 7, imagem 1 %32
    • Remove the speakers from the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 47
Duração total: 781
