Ir para o conteúdo principal
Lenovo Legion Y530-15ICH Solid State Drive Replacement
O que você precisa
  1. Lenovo Legion Y530-15ICH Solid State Drive Replacement, Back Cover: passo 1, imagem 1 %32
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH Solid State Drive Replacement: passo 2, imagem 1 %32 Lenovo Legion Y530-15ICH Solid State Drive Replacement: passo 2, imagem 2 %32
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Solid State Drive Replacement, Solid State Drive: passo 3, imagem 1 %32 Lenovo Legion Y530-15ICH Solid State Drive Replacement, Solid State Drive: passo 3, imagem 2 %32
    • Do not remove the thermal pad.
    • Remove one 4mm screw circled in orange in the second picture with a JIS #1 screwdriver.
  4. Lenovo Legion Y530-15ICH Solid State Drive Replacement: passo 4, imagem 1 %32 Lenovo Legion Y530-15ICH Solid State Drive Replacement: passo 4, imagem 2 %32
    • Carefully remove the SSD from its connector.
Conclusão
Insert your new SSD into the connector. To reassemble your device, follow these instructions in reverse order.
Uma outra pessoa concluiu este guia.
Kaylie Klausing
Membro desde: 02/07/20
758 Reputação
6 Guias de autoria
Equipe
Cal Poly, Team S7-G1, Regan Winter 2020 Membro de Cal Poly, Team S7-G1, Regan Winter 2020
CPSU-REGAN-W20S7G1
4 Membros
11 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 23
Últimos 30 dias: 123
Duração total: 3,906
