Introdução
This guide will show you how to replace the RAM in the Lenovo Legion 520-IKBN. You would replace the RAM if computer is acting slower than it is or if your startup screen is a black screen.
O que você precisa
Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
There is a piece of plastic covering part of the RAM and the fan. You will need to remove this to get to the RAM.
11 outras pessoas executaram este guia.
3 comentários
Hi, can i add any 8gb 2400mhz ddr4 kit bought online? or does it have to be a specific kind?
Thank you for the guide
Here’s a link for the compatible ones https://www.crucial.de/deu/de/upgrade-ko...
