Ir para o conteúdo principal
Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement
O que você precisa
  1. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: passo 1, imagem 1 %32 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: passo 1, imagem 2 %32 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement, Keyboard Keycap: passo 1, imagem 3 %32
    • Carefully remove the broken key(s). Use the flat end of the spudger to gently pop the key off.
    • When removing the key(s) be very cautious not to remove the white plastic pieces underneath with it.
    • When reinstalling key, no spudger is needed. Just pop it into place with fingers.
  2. Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: passo 2, imagem 1 %32 Lenovo Legion Y520-15IKBN Keyboard Keycap Replacement: passo 2, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the flat end of the spudger, very carefully lift up the corners of the white plastic piece. Do not disconnect the two.
    • With the help of tweezers (needle nose works best), pull the connected plastic pieces out.
    • If the two plastic pieces come apart refer to the last picture, showing the orientation in which they should be connected.
    • For reinstallation of the plastic piece use tweezers to put it back in place and pop the bottom half in before the top.
Conclusão
3 comentários
This is only for the key caps, what about the keyboard itself?
Rick Montoya - Responder
I agree the video is mislabeled. You are not replacing the board just keys.
Pat Schutte - Responder
Please create a tutorial for keys with stabilizer like space bar and enter keys.
Affix - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 23
Últimos 30 dias: 143
Duração total: 10,411
