Ir para o conteúdo principal
Lenovo Legion Y520-15IKBN Fan Replacement
O que você precisa
  1. Lenovo Legion Y520-15IKBN Fan Replacement, Base Panel: passo 1, imagem 1 %32 Lenovo Legion Y520-15IKBN Fan Replacement, Base Panel: passo 1, imagem 2 %32
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Fan Replacement: passo 2, imagem 1 %32
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
  3. Lenovo Legion Y520-15IKBN Fan Replacement, Fan: passo 3, imagem 1 %32 Lenovo Legion Y520-15IKBN Fan Replacement, Fan: passo 3, imagem 2 %32 Lenovo Legion Y520-15IKBN Fan Replacement, Fan: passo 3, imagem 3 %32
    • There is a piece of plastic covering part of the RAM and the fan. You will need to remove this to get to the fan.
    • Unplug the battery then, you will need to remove the four 4 mm screws around the fan using a Phillips #00 screwdriver.
  4. Lenovo Legion Y520-15IKBN Fan Replacement: passo 4, imagem 1 %32 Lenovo Legion Y520-15IKBN Fan Replacement: passo 4, imagem 2 %32 Lenovo Legion Y520-15IKBN Fan Replacement: passo 4, imagem 3 %32
    • Unscrew all the screws then unplug the wires connected to the fan.
    • Once all the wires are unplugged from the fan, move the wires aside to get the fan.
  5. Lenovo Legion Y520-15IKBN Fan Replacement: passo 5, imagem 1 %32 Lenovo Legion Y520-15IKBN Fan Replacement: passo 5, imagem 2 %32 Lenovo Legion Y520-15IKBN Fan Replacement: passo 5, imagem 3 %32
    • Lift the fan out of the laptop body.
Conclusão
9 outras pessoas executaram este guia.
3 comentários
Superb guide. thank you random citizen for creating this guide
Fikri Nur Nafi - Responder
Do I need to remove the fan if I want to clean it or add oil?
Ziro Hutt - Responder
Is there a way to open the fan to clean the dust from the blade ?
Apalagi08 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 47
Duração total: 7,401
