Introdução
Detailed steps to dissasemble to the logic board, then usefull pictures for rest of guide. (remember to add new thermal compound if you need to remove/replace fan assembly on processor and GPU)
O que você precisa
recommend to print out picture of the backside of the laptop and then use it as a template to place the screws on. They are many and different sizes.
Remove all bottom screws and place on template printout.
usefull images showing most of main assembly.
Removing RAM modules is usefull if the whole logic board needs to be taken out.
From here on , unscrew everything - carefully note where screws belong. I used Ifixit magnetic mat and some note making.
8 outras pessoas executaram este guia.
