Ir para o conteúdo principal
Lenovo Laptop T400 Motherboard Replacement
O que você precisa
  1. Lenovo Laptop T400 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • recommend to print out picture of the backside of the laptop and then use it as a template to place the screws on. They are many and different sizes.
    • Remove all bottom screws and place on template printout.
  2. Lenovo Laptop T400 Motherboard Replacement: passo 2, imagem 1 %32 Lenovo Laptop T400 Motherboard Replacement: passo 2, imagem 2 %32
    • Remove DVD drive. Toggle the "play triangle" switch so that the tab extends. Pull the tab to remove the DVD drive.
    • Remove hard drive
  3. Lenovo Laptop T400 Motherboard Replacement: passo 3, imagem 1 %32 Lenovo Laptop T400 Motherboard Replacement: passo 3, imagem 2 %32 Lenovo Laptop T400 Motherboard Replacement: passo 3, imagem 3 %32
    • unsnap touchpad left and right.
    • lift up touchpad carefully, and disconnect touchpad.
  4. Lenovo Laptop T400 Motherboard Replacement: passo 4, imagem 1 %32 Lenovo Laptop T400 Motherboard Replacement: passo 4, imagem 2 %32
    • Pull keyboard gently toward yourself. and then lift up untill flex is visible.
    • use spudger to disconnect connector for keyboard.
  5. Lenovo Laptop T400 Motherboard Replacement: passo 5, imagem 1 %32
    • The rest of the guide is mosly helpfull pictures...
    • Remove WLAN module by
    • unplug carefully with spudger the two RF connectors to WLAN module.
    • remove the two screws holding wlan module.
    • lift up module 45 degress and pull outwards.
  6. Lenovo Laptop T400 Motherboard Replacement: passo 6, imagem 1 %32 Lenovo Laptop T400 Motherboard Replacement: passo 6, imagem 2 %32 Lenovo Laptop T400 Motherboard Replacement: passo 6, imagem 3 %32
    • usefull images showing most of main assembly.
    • Removing RAM modules is usefull if the whole logic board needs to be taken out.
    • From here on , unscrew everything - carefully note where screws belong. I used Ifixit magnetic mat and some note making.
  7. Lenovo Laptop T400 Motherboard Replacement: passo 7, imagem 1 %32
    • one more image to help you
Conclusão
8 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 15
Últimos 30 dias: 56
Duração total: 11,665
