Introdução
How to remove the motherboard from the device.
O que você precisa
Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
The speakers are connected to the tablet by glue and require a lot of prying to remove.
Make sure to get all the way under the speakers when prying.
Unlike the other small connectors this one does not flip up. You need to pull the connector cable to release this
Lift the tab by pulling it up with your hand.
Don't forget the Camera connector on the opposite side! :) Almost missed him.
8 outras pessoas executaram este guia.
3 comentários
Just followed this on my father's tablet, worked like a charm!
One step missing, there's a connector for the camera between steps 16 and 17 that needs pried up before taking the board off.
Other than that THANK YOU!!! :)
Any schematics or board view for this board out there?
Best purchase of mother board?
I little bit of heat goes a long way when taking off the speaker screens.
iHelpU.Tech - Responder
