Ir para o conteúdo principal
Lenovo Ideatab A1107 Battery Replacement
O que você precisa
  1. Lenovo Ideatab A1107 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Lenovo Ideatab A1107 Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • Insert a plastic opener in-between the black back panel and the silver body of the tablet.
    • Use the plastic opener to pry the back panel off by moving the plastic opener around the outside edge of the device.
  2. Lenovo Ideatab A1107 Battery Replacement: passo 2, imagem 1 %32 Lenovo Ideatab A1107 Battery Replacement: passo 2, imagem 2 %32
    • Use a Phillips #000 screwdriver to remove the seventeen 4mm screws.
  3. Lenovo Ideatab A1107 Battery Replacement: passo 3, imagem 1 %32
    • Lift up and remove the interior casing to expose the inner components.
    • Do not be alarmed if the volume button and lock button fall off when removing the interior casing.
  4. Lenovo Ideatab A1107 Battery Replacement, Battery: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to remove the tape covering the battery's wiring.
  5. Lenovo Ideatab A1107 Battery Replacement: passo 5, imagem 1 %32 Lenovo Ideatab A1107 Battery Replacement: passo 5, imagem 2 %32
    • Do not puncture the lithium-ion battery. Ruptured batteries can catch fire or explode.
    • Do not use metal tools to remove the battery wire. They present the risk of electrocution.
    • Use a plastic spudger tool to push the battery's wire harness and disconnect it from the device.
  6. Lenovo Ideatab A1107 Battery Replacement: passo 6, imagem 1 %32
    • Wedge a plastic opening tool in between the battery and the internal components of the device.
    • Use the plastic opener tool to remove the battery from its casing.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Duração total: 417
