Ir para o conteúdo principal
Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset)
O que você precisa
Vídeo de Apresentação
  1. Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset), Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): passo 1, imagem 1 %32
    • First of all you can try soft reset from the reset switch. This method does not delete the data from the tablet.
  2. Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): passo 2, imagem 1 %32 Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): passo 2, imagem 2 %32 Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): passo 2, imagem 3 %32
    • Now - hardware reset:
    • Switch off the tablet.
    • Press and hold at the same time Volume UP and Power keys.
    • When the System Recovery screen appears use the Volume Up/Down keys for navigation and the Power On key for OK.
    • Choose "wipe data / factory reset", "Yes -- delete all user data", "reboot system now".
  3. Lenovo Ideatab A1000 Wipe Data / Factory Reset (Hard Reset): passo 3, imagem 1 %32
    • That's all.
Conclusão
47 outras pessoas executaram este guia.
ZFix
Membro desde: 12/09/13
191.368 Reputação
Autoria de 330 guias
Equipe
Master Techs Membro de Master Techs
Community
Membros da 321
Autoria de 1.468 guias
36 comentários
If device is connected to charger that button combination doesn't work. It goes to hardware test menu.
Pekka Lounatvuori - Responder
How to reser chinese language lenova phone
With Chinese phones, you do not need to use other options, and there is no confirmation. The wipe simply starts, and completes by wiping your phone. Read more - http://www.gogorapid.com/how-to-reset-ch...
Rumal Roma - Responder
My lenovo a 1000 idea tab's display is gone....no bottom in work...how to reset or fix it
ashiquehossain15 - Responder
my lenovo s850 is on meta mode when i press vol down + power button and nothing appear when i press vol up + power button.. the thing is i've tried many button sequence but i just cat get into reset mode or cynogen mode.. :(
wooblegooble92 - Responder
My lenovo tab isnt working until it went to some sort of menu using volume buttons but then i actually pressed something and it went to a screen saying "Now send the package you want to apply to the device using adb sideload <filename>" how do i go back to the reboot menu
Albert Einstein - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 46
Últimos 30 dias: 239
Duração total: 400,929
