Introdução
If your trackpad stops working or has any performance issues, you can follow this guide to remove and replace it.
O que você precisa
Begin by turning your closed laptop so that you are looking at the bottom panel.
Locate the battery in the bottom right corner.
Using a Phillips #000, remove the 6 screws (3.5mm) on the border of the battery and the 7th screw (6.5mm) that is in the center of the battery.
