Ir para o conteúdo principal
Lenovo Ideapad Yoga 2 11 Battery Replacement
O que você precisa
  1. Lenovo Ideapad Yoga 2 11 Battery Replacement, Back Panel: passo 1, imagem 1 %32
    • Begin by turning your closed laptop so that you are looking at the bottom panel.
  2. Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 2, imagem 1 %32 Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 2, imagem 2 %32
    • Locate the 10 screws (6mm) around the border of the panel.
    • Using the Torx T5 Screwdriver, remove the screws.
  3. Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 3, imagem 1 %32
    • Now that the screws are removed, gently lift the back panel upwards to detach it from the rest of your laptop.
  4. Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: passo 4, imagem 1 %32 Lenovo Ideapad Yoga 2 11 Battery Replacement, Battery: passo 4, imagem 2 %32
    • Locate the battery in the bottom right corner.
    • Using a Phillips #000, remove the 6 screws (3.5mm) on the border of the battery and the 7th screw (6.5mm) that is in the center of the battery.
  5. Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 5, imagem 1 %32 Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 5, imagem 2 %32 Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Locate the cable connecting to the battery. It is located at the top-center of the battery.
    • Use a pair of tweezers and place it so that the tweezer is around the cables. Gently pull the cables towards the battery to disconnect the cable.
  6. Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 6, imagem 1 %32 Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 6, imagem 2 %32
    • There may be tape around the edge of the battery to secure some wires. Use a pair of tweezers to remove the tape so that the wires are no longer attached to the battery.
  7. Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 7, imagem 1 %32 Lenovo Ideapad Yoga 2 11 Battery Replacement: passo 7, imagem 2 %32
    • After you have unscrewed the screws, unplugged the cable, and removed the tape and wires, you can remove the battery from your laptop.
Conclusão
Andria Chen
Membro desde: 10/17/17
624 Reputação
Autoria de 5 guias
Equipe
Um comentário
Excellent instructions makes it easy even for novice
bhimanagouda patil - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 1,845
