Ir para o conteúdo principal
Lenovo Ideapad S415 Touch Fan Replacement
O que você precisa
  1. Lenovo Ideapad S415 Touch Fan Replacement, Battery: passo 1, imagem 1 %32
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Fan Replacement: passo 2, imagem 1 %32
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Fan Replacement: passo 3, imagem 1 %32
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Fan Replacement: passo 4, imagem 1 %32
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Fan Replacement: passo 5, imagem 1 %32
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch Fan Replacement, Fan: passo 6, imagem 1 %32 Lenovo Ideapad S415 Touch Fan Replacement, Fan: passo 6, imagem 2 %32
    • Locate the five 6mm black screws on the bottom.
    • Using a Phillips #0 screwdriver, remove all five black screws.
  7. Lenovo Ideapad S415 Touch Fan Replacement: passo 7, imagem 1 %32 Lenovo Ideapad S415 Touch Fan Replacement: passo 7, imagem 2 %32
    • Locate the three 4mm silver screws on the bottom area where the battery was removed.
    • Using the Phillips #0 screwdriver, remove all three silver screws.
  8. Lenovo Ideapad S415 Touch Fan Replacement: passo 8, imagem 1 %32 Lenovo Ideapad S415 Touch Fan Replacement: passo 8, imagem 2 %32 Lenovo Ideapad S415 Touch Fan Replacement: passo 8, imagem 3 %32
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stoppers by lifting each with your fingers.
  9. Lenovo Ideapad S415 Touch Fan Replacement: passo 9, imagem 1 %32 Lenovo Ideapad S415 Touch Fan Replacement: passo 9, imagem 2 %32 Lenovo Ideapad S415 Touch Fan Replacement: passo 9, imagem 3 %32
    • Under each of the four stoppers, there will be a 6mm screw.
    • Use the Phillips #0 screwdriver to remove all four screws.
  10. Lenovo Ideapad S415 Touch Fan Replacement: passo 10, imagem 1 %32 Lenovo Ideapad S415 Touch Fan Replacement: passo 10, imagem 2 %32
    • Carefully open up the laptop to reveal the internal components.
  11. Lenovo Ideapad S415 Touch Fan Replacement: passo 11, imagem 1 %32 Lenovo Ideapad S415 Touch Fan Replacement: passo 11, imagem 2 %32
    • Locate the silver 6mm screw on the top of the fan
    • Locate the silver 4mm screw on the bottom of the fan
    • Use a Phillips #0 screwdriver to remove both screws.
  12. Lenovo Ideapad S415 Touch Fan Replacement: passo 12, imagem 1 %32 Lenovo Ideapad S415 Touch Fan Replacement: passo 12, imagem 2 %32
    • Locate the fan power connector.
    • Use a spudger or your hands to disconnect the fan power connector from its port.
  13. Lenovo Ideapad S415 Touch Fan Replacement: passo 13, imagem 1 %32 Lenovo Ideapad S415 Touch Fan Replacement: passo 13, imagem 2 %32
    • Once the fan power connector is disconnected, lift up the bronze heatsink and pull the wires out from underneath it.
    • Lift up the fan and pull free.
Conclusão
Alexandria
Membro desde: 02/05/19
363 Reputação
Autoria de 2 guias
Equipe
UC Davis, Team S20-G5, Lore Winter 2019 Membro de UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
Membros da 3
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 190
