Ir para o conteúdo principal
Lenovo Ideapad Flex 15 RAM Replacement
O que você precisa
  1. Lenovo Ideapad Flex 15 RAM Replacement, Bottom Panel: passo 1, imagem 1 %32 Lenovo Ideapad Flex 15 RAM Replacement, Bottom Panel: passo 1, imagem 2 %32
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 RAM Replacement: passo 2, imagem 1 %32 Lenovo Ideapad Flex 15 RAM Replacement: passo 2, imagem 2 %32
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 RAM Replacement: passo 3, imagem 1 %32 Lenovo Ideapad Flex 15 RAM Replacement: passo 3, imagem 2 %32 Lenovo Ideapad Flex 15 RAM Replacement: passo 3, imagem 3 %32
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 RAM Replacement: passo 4, imagem 1 %32
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 RAM Replacement: passo 5, imagem 1 %32 Lenovo Ideapad Flex 15 RAM Replacement: passo 5, imagem 2 %32 Lenovo Ideapad Flex 15 RAM Replacement: passo 5, imagem 3 %32
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 RAM Replacement: passo 6, imagem 1 %32 Lenovo Ideapad Flex 15 RAM Replacement: passo 6, imagem 2 %32
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
  7. Lenovo Ideapad Flex 15 RAM Replacement, RAM: passo 7, imagem 1 %32 Lenovo Ideapad Flex 15 RAM Replacement, RAM: passo 7, imagem 2 %32
    • Once open, locate the RAM stick below the fan on the bottom right corner of the Flex 15.
    • At the same time, using two hands, pull both clips away from the RAM module.
  8. Lenovo Ideapad Flex 15 RAM Replacement: passo 8, imagem 1 %32 Lenovo Ideapad Flex 15 RAM Replacement: passo 8, imagem 2 %32
    • The RAM stick should start to tilt upwards. Once you see this, pull the stick diagonally towards the top of the laptop.
    • Be careful and do not apply extra pressure on the RAM.
    • If you feel that it will snap, pull the clips apart farther to loosen the RAM connection. Then try again.
Conclusão
3 outras pessoas executaram este guia.
Brent
Membro desde: 03/04/16
804 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 6-6, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 6-6, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 16
Duração total: 3,051
