Ir para o conteúdo principal
Lenovo Ideapad Flex 15 Hard Drive Replacement
O que você precisa
  1. Lenovo Ideapad Flex 15 Hard Drive Replacement, Bottom Panel: passo 1, imagem 1 %32 Lenovo Ideapad Flex 15 Hard Drive Replacement, Bottom Panel: passo 1, imagem 2 %32
    • Start by removing the feet near the LCD hinge of the laptop to reveal two screws.
    • Using a Phillips #1 screwdriver, remove the top five (30 mm) screws underneath the battery.
  2. Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 2, imagem 1 %32 Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 2, imagem 2 %32
    • Once both feet are removed, two (40 mm) screws will reveal themselves. Unscrew these.
  3. Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 3, imagem 1 %32 Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 3, imagem 2 %32 Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 3, imagem 3 %32
    • Working your way around the outer edges of the Flex 15, remove the 8 (30 mm) outer screws.
  4. Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 4, imagem 1 %32
    • Remove the one (40 mm) screw in the middle of the Flex 15.
  5. Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 5, imagem 1 %32 Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 5, imagem 2 %32 Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 5, imagem 3 %32
    • Using a plastic opening tool, make your way around the edge of the laptop.
    • There is a visible line between the bottom shell of the laptop and the laptop body itself.
  6. Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 6, imagem 1 %32 Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 6, imagem 2 %32
    • Make sure to pry evenly around this edge and only remove the bottom of the laptop when it is fully loose.
    • Using excessive force may break the bottom plastic. There are plastic clips along the edge of the laptop.
  7. Lenovo Ideapad Flex 15 Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32
    • Locate the hard drive assembly on the top right hand corner of the Flex 15 based on the orientation of the device in the picture.
  8. Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 8, imagem 1 %32 Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 8, imagem 2 %32 Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 8, imagem 3 %32
    • Begin by unscrewing the four (20 mm) black screws that surround the hard drive’s metal cage.
    • Once removed, remove the black SATA connector by pulling it from the hard drive unit towards the right hand side of the laptop.
  9. Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 9, imagem 1 %32 Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 9, imagem 2 %32 Lenovo Ideapad Flex 15 Hard Drive Replacement: passo 9, imagem 3 %32
    • The hard drive should be freed from the base of the laptop.
    • There are four (20 mm) black screws surrounding the hard drive from the cage. Unscrew these to free the hard drive from the cage
Conclusão
6 outras pessoas executaram este guia.
Brent
Membro desde: 03/04/16
804 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team 6-6, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 6-6, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G6
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 6,927
