Ir para o conteúdo principal
Lenovo Ideapad 320-17IKB Fan Replacement
O que você precisa
  1. Lenovo Ideapad 320-17IKB Fan Replacement, Back Panel: passo 1, imagem 1 %32
    • Turn off and unplug the computer.
    • Flip the laptop over so that the back panel is facing upwards.
  2. Lenovo Ideapad 320-17IKB Fan Replacement: passo 2, imagem 1 %32 Lenovo Ideapad 320-17IKB Fan Replacement: passo 2, imagem 2 %32
    • Remove fourteen 7mm Phillips #00 screws from the back panel.
  3. Lenovo Ideapad 320-17IKB Fan Replacement: passo 3, imagem 1 %32
    • Carefully remove the optical drive by pulling the bezel away from the laptop.
  4. Lenovo Ideapad 320-17IKB Fan Replacement: passo 4, imagem 1 %32 Lenovo Ideapad 320-17IKB Fan Replacement: passo 4, imagem 2 %32
    • Use your fingers or an opening tool to gently remove the back panel from the bottom of the laptop.
    • Lay both sides of the laptop next to each other.
  5. Lenovo Ideapad 320-17IKB Fan Replacement, Battery: passo 5, imagem 1 %32 Lenovo Ideapad 320-17IKB Fan Replacement, Battery: passo 5, imagem 2 %32
    • Remove five 7mm Phillips #0 screws from the battery holder.
  6. Lenovo Ideapad 320-17IKB Fan Replacement: passo 6, imagem 1 %32 Lenovo Ideapad 320-17IKB Fan Replacement: passo 6, imagem 2 %32
    • Pinch the connecting cord with one hand and pry the battery connector with the other hand, while gently pulling the connector straight out and towards the bottom edge of the base.
    • When removing the battery, use care to keep it flat and do not open the battery because it can result in fire or explosion.
  7. Lenovo Ideapad 320-17IKB Fan Replacement, Fan: passo 7, imagem 1 %32 Lenovo Ideapad 320-17IKB Fan Replacement, Fan: passo 7, imagem 2 %32
    • Remove five 7mm Phillips #00 screws from the cooling fan.
  8. Lenovo Ideapad 320-17IKB Fan Replacement: passo 8, imagem 1 %32 Lenovo Ideapad 320-17IKB Fan Replacement: passo 8, imagem 2 %32 Lenovo Ideapad 320-17IKB Fan Replacement: passo 8, imagem 3 %32
    • Gently lift the fan assembly out of the laptop.
    • Gently remove the connecting wires from the exterior of the fan by slowly "weaving" the cord between the ridges of the fan.
Conclusão
Uma outra pessoa concluiu este guia.
Kristen Gismondi
Membro desde: 11/12/14
82.323 Reputação
Autoria de 200 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.303 guias
Um comentário
Very helpful instructions. However, Step 6 indicates that you should remove 5 screws, but really you only need the 2 on the left that are actually connecting the fan to the system board, the rest are unnecessary. In fact, the machine I replaced this on only had the one screw in the top-left.
Jeff Breuer - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 22
Duração total: 785
