Ir para o conteúdo principal
Lenovo Ideapad 320-15IAP Hard Drive Replacement
O que você precisa
  1. Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32 Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: passo 1, imagem 2 %32
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back panel.
  2. Lenovo Ideapad 320-15IAP Hard Drive Replacement: passo 2, imagem 1 %32 Lenovo Ideapad 320-15IAP Hard Drive Replacement: passo 2, imagem 2 %32
    • Remove the CD reader with an opening tool. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Lift the cover using the opening tool on different spots along the side of the laptop.
  3. Lenovo Ideapad 320-15IAP Hard Drive Replacement: passo 3, imagem 1 %32
    • Remove the hard drive by inserting your finger under the highlighted area, then pushing up then pulling left to remove the drive.
    • Remove the adapter from the drive, then insert the new drive into the adapter.
    • To insert the new drive, gently place it into the enclosure for the hard drive and push carefully into the SATA slot.
Conclusão
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 63
Ao todo: 1,685
