Ir para o conteúdo principal
Lenovo Ideapad 320-15IAP Battery Replacement
O que você precisa
  1. Lenovo Ideapad 320-15IAP Battery Replacement, Battery: passo 1, imagem 1 %32 Lenovo Ideapad 320-15IAP Battery Replacement, Battery: passo 1, imagem 2 %32
    • Before you begin, be sure to turn off your laptop and unplug it from the outlet.
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back case.
  2. Lenovo Ideapad 320-15IAP Battery Replacement: passo 2, imagem 1 %32
    • Pull the CD drive outwards with an opening tool until it pops out as shown. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Remove the CD drive.
  3. Lenovo Ideapad 320-15IAP Battery Replacement: passo 3, imagem 1 %32
    • Lift up the cover using the opening tool on different spots along the side of the laptop.
  4. Lenovo Ideapad 320-15IAP Battery Replacement: passo 4, imagem 1 %32 Lenovo Ideapad 320-15IAP Battery Replacement: passo 4, imagem 2 %32
    • Using a Phillips #0 screwdriver to unscrew the four 5.5 mm screws securing the battery.
  5. Lenovo Ideapad 320-15IAP Battery Replacement: passo 5, imagem 1 %32 Lenovo Ideapad 320-15IAP Battery Replacement: passo 5, imagem 2 %32
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
  6. Lenovo Ideapad 320-15IAP Battery Replacement: passo 6, imagem 1 %32
    • Remove the battery.
Conclusão
For optimal performance, after completing this guide, calibrate your newly installed battery.
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 55
Duração total: 1,082
