Ir para o conteúdo principal
Lenovo Ideapad 320-15ABR Screen Replacement
O que você precisa
  1. Lenovo Ideapad 320-15ABR Screen Replacement, Screen: passo 1, imagem 1 %32 Lenovo Ideapad 320-15ABR Screen Replacement, Screen: passo 1, imagem 2 %32 Lenovo Ideapad 320-15ABR Screen Replacement, Screen: passo 1, imagem 3 %32
    • Begin by prying off the black cover surrounding the screen by wedging the the iFixit opening tool underneath it. Work your way down until you reach the hinge cover.
    • Insert iFixit opening tool in to the hinge cover as pictured and begin slowly prying it off.
    • This will require some force, but take care not to break the hinge cover.
    • Remove the black cover.
  2. Lenovo Ideapad 320-15ABR Screen Replacement: passo 2, imagem 1 %32 Lenovo Ideapad 320-15ABR Screen Replacement: passo 2, imagem 2 %32 Lenovo Ideapad 320-15ABR Screen Replacement: passo 2, imagem 3 %32
    • Using the Phillips #1 screwdriver, remove the four 3mm screws securing the screen, and put them on the magnetic mat so you will not misplace them.
    • Gently lift the screen out and place it facing down on the keyboard.
  3. Lenovo Ideapad 320-15ABR Screen Replacement: passo 3, imagem 1 %32 Lenovo Ideapad 320-15ABR Screen Replacement: passo 3, imagem 2 %32 Lenovo Ideapad 320-15ABR Screen Replacement: passo 3, imagem 3 %32
    • Carefully flip the hinge securing the connector up with the opening tool.
    • Slowly work the plug out of the connector.
    • Do not pull by the the cable, as the cable is fragile.
    • Insert the plug from the replacement screen in to the connector. Make sure the connection is secure before flipping the hinge back down.
Conclusão
3 outras pessoas executaram este guia.
Um comentário
How to replace hinge for this model
Deepak Singh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 22
Duração total: 4,570
