Ir para o conteúdo principal
Lenovo Ideapad 320-15ABR Fan Replacement
O que você precisa
  1. Lenovo Ideapad 320-15ABR Fan Replacement, Back Panel: passo 1, imagem 1 %32
    • Before you proceed, make sure your computer is turned off and is not connected to any power source.
    • Remove the single 7 mm Phillips #1 screw securing the optical drive.
    • Be sure to store the screws carefully as they are easy to lose. A magnetic project mat is recommended
  2. Lenovo Ideapad 320-15ABR Fan Replacement: passo 2, imagem 1 %32 Lenovo Ideapad 320-15ABR Fan Replacement: passo 2, imagem 2 %32 Lenovo Ideapad 320-15ABR Fan Replacement: passo 2, imagem 3 %32
    • Carefully remove the optical drive bracket by pulling the bezel away from the laptop.
  3. Lenovo Ideapad 320-15ABR Fan Replacement: passo 3, imagem 1 %32 Lenovo Ideapad 320-15ABR Fan Replacement: passo 3, imagem 2 %32
    • Using the Phillips #1 screwdriver, remove the twelve screws around the back panel from the laptop.
  4. Lenovo Ideapad 320-15ABR Fan Replacement: passo 4, imagem 1 %32 Lenovo Ideapad 320-15ABR Fan Replacement: passo 4, imagem 2 %32 Lenovo Ideapad 320-15ABR Fan Replacement: passo 4, imagem 3 %32
    • Use an opening tool to pry out the back cover.
  5. Lenovo Ideapad 320-15ABR Fan Replacement: passo 5, imagem 1 %32 Lenovo Ideapad 320-15ABR Fan Replacement: passo 5, imagem 2 %32 Lenovo Ideapad 320-15ABR Fan Replacement: passo 5, imagem 3 %32
    • Remove the back panel by pulling it up and away from the laptop.
  6. Lenovo Ideapad 320-15ABR Fan Replacement, Battery: passo 6, imagem 1 %32
    • Remove the four 6mm screws using the Phillips #1 screwdriver.
  7. Lenovo Ideapad 320-15ABR Fan Replacement: passo 7, imagem 1 %32 Lenovo Ideapad 320-15ABR Fan Replacement: passo 7, imagem 2 %32
    • Disconnect the battery connector by pulling toward the battery parallel to the motherboard.
  8. Lenovo Ideapad 320-15ABR Fan Replacement: passo 8, imagem 1 %32
    • Remove the battery.
  9. Lenovo Ideapad 320-15ABR Fan Replacement, Fan: passo 9, imagem 1 %32 Lenovo Ideapad 320-15ABR Fan Replacement, Fan: passo 9, imagem 2 %32
    • Disconnect black and grey wires by simply giving them a light tug.
  10. Lenovo Ideapad 320-15ABR Fan Replacement: passo 10, imagem 1 %32
    • Remove the 6mm Phillips #1 screw connecting the fan to the laptop.
  11. Lenovo Ideapad 320-15ABR Fan Replacement: passo 11, imagem 1 %32 Lenovo Ideapad 320-15ABR Fan Replacement: passo 11, imagem 2 %32 Lenovo Ideapad 320-15ABR Fan Replacement: passo 11, imagem 3 %32
    • Lift the fan slightly and straight upward and unwind the black and grey wires from the fan.
  12. Lenovo Ideapad 320-15ABR Fan Replacement: passo 12, imagem 1 %32
    • Identify the red, black, yellow, and brown wire coming from the back of the fan connecting to the motherboard with a white connector piece.
  13. Lenovo Ideapad 320-15ABR Fan Replacement: passo 13, imagem 1 %32 Lenovo Ideapad 320-15ABR Fan Replacement: passo 13, imagem 2 %32
    • Slowly pull and wiggle the white connector piece until it comes loose from the laptop.
  14. Lenovo Ideapad 320-15ABR Fan Replacement: passo 14, imagem 1 %32
    • Replace the new fan.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 45
Duração total: 5,071
