Ir para o conteúdo principal
Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement
O que você precisa
  1. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement, Back Cover: passo 1, imagem 1 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement, USB Daughterboard: passo 3, imagem 1 %32 Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement, USB Daughterboard: passo 3, imagem 2 %32
    • Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
  4. Lenovo Ideapad 120s-14IAP USB Daughterboard Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, disconnect the speaker on the left from the USB daugterboard.
    • Remove two 2.5 mm Phillips #0 screws from the daughterboard.
    • Remove the daughterboard from the laptop.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 752
