Ir para o conteúdo principal
Lenovo Ideapad 120s-14IAP Touchpad Replacement
O que você precisa
  1. Lenovo Ideapad 120s-14IAP Touchpad Replacement, Back Cover: passo 1, imagem 1 %32
    • Be sure to power off and unplug your device before you begin your repair.
    • Orient the laptop so the top is laying flat on your work surface.
    • Remove ten 1.5mm Torx T5 screws from the back of the laptop.
  2. Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 2, imagem 1 %32
    • Insert the plastic opening tool or a Jimmy along the edge of the back cover and gently pry.
    • Run the tool all the way around the edge of the back cover and remove the back cover once it is no longer secure.
    • Remove the back cover.
  3. Lenovo Ideapad 120s-14IAP Touchpad Replacement, USB Daughterboard: passo 3, imagem 1 %32 Lenovo Ideapad 120s-14IAP Touchpad Replacement, USB Daughterboard: passo 3, imagem 2 %32
    • Use a spudger to lift the black fastener and disconnect the ribbon cable from the USB daughterboard.
  4. Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 4, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, disconnect the speaker on the left from the USB daugterboard.
    • Remove two 2.5 mm Phillips #0 screws from the daughterboard.
    • Remove the daughterboard from the laptop.
  5. Lenovo Ideapad 120s-14IAP Touchpad Replacement, Motherboard: passo 5, imagem 1 %32 Lenovo Ideapad 120s-14IAP Touchpad Replacement, Motherboard: passo 5, imagem 2 %32 Lenovo Ideapad 120s-14IAP Touchpad Replacement, Motherboard: passo 5, imagem 3 %32
    • Using a spudger, disconnect the keyboard ribbon cable from the motherboard.
    • Pull on the plastic film to remove the display connection cable.
  6. Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 6, imagem 1 %32
    Comprar
    • Using tweezers, disconnect the connections for the right speaker.
    • Using tweezers, disconnect the connections for the battery.
    • Using tweezers, disconnect the connections for the CMOS battery.
  7. Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 7, imagem 1 %32
    • Remove the wireless card by disconnecting the two antenna cables and removing the 2.5 mm Phillips #0 screw.
  8. Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 8, imagem 1 %32 Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 8, imagem 2 %32
    • Remove seven 2.5 mm Phillips #0 screws from the motherboard.
    • Slide the motherboard out of the laptop chassis.
  9. Lenovo Ideapad 120s-14IAP Touchpad Replacement, Touchpad: passo 9, imagem 1 %32 Lenovo Ideapad 120s-14IAP Touchpad Replacement, Touchpad: passo 9, imagem 2 %32
    • Remove five 2.5 mm Phillips #0 screws from around the battery.
    • Lift the battery out of the laptop.
  10. Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 10, imagem 1 %32 Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 10, imagem 2 %32
    • Remove four 2.0 mm Phillips #0 screws from the speaker assemblies.
    • The speakers can now be lifted up.
  11. Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 11, imagem 1 %32 Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 11, imagem 2 %32
    • Remove six 2.5 mm Phillips #0 screws from the battery bracket.
    • Lift the battery bracket out of the laptop.
  12. Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 12, imagem 1 %32 Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 12, imagem 2 %32
    • Remove six 5.0 mm Phillips #0 screws from the screen hinges.
    • You can now lift the bottom cover and separate each half of the laptop.
  13. Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 13, imagem 1 %32 Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 13, imagem 2 %32 Lenovo Ideapad 120s-14IAP Touchpad Replacement: passo 13, imagem 3 %32
    • The touchpad retention screws are hidden beneath a strip of adhesive. Gently peel the adhesive away to access them.
    • Remove three 2.0 mm Phillips #0 screws from the touchpad retention bracket.
    • The touchpad now slides up and can be removed.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 13
Duração total: 875
