Ir para o conteúdo principal
Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement
O que você precisa
  1. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement, Battery: passo 1, imagem 1 %32
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 2, imagem 1 %32 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 2, imagem 2 %32
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 3, imagem 1 %32 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 3, imagem 2 %32
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 4, imagem 1 %32
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 5, imagem 1 %32 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 5, imagem 2 %32
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement, Wi-Fi Card: passo 6, imagem 1 %32
    • Locate the Wi-Fi card.
  7. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 7, imagem 1 %32
    • Disconnect the two wires that are connected to the Wi-Fi card by gently pulling them up.
  8. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 8, imagem 1 %32 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 8, imagem 2 %32
    • Unscrew the one 4mm screw keeping the card in place.
  9. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 9, imagem 1 %32 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 9, imagem 2 %32
    • Gently pull the Wi-Fi card out of place.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 12
Duração total: 1,184
