Ir para o conteúdo principal
Lenovo Ideapad 110S-11IBR Touchpad Replacement
O que você precisa
  1. Lenovo Ideapad 110S-11IBR Touchpad Replacement, Battery: passo 1, imagem 1 %32
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Touchpad Replacement: passo 2, imagem 1 %32 Lenovo Ideapad 110S-11IBR Touchpad Replacement: passo 2, imagem 2 %32
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Touchpad Replacement: passo 3, imagem 1 %32 Lenovo Ideapad 110S-11IBR Touchpad Replacement: passo 3, imagem 2 %32
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Touchpad Replacement: passo 4, imagem 1 %32
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Touchpad Replacement: passo 5, imagem 1 %32 Lenovo Ideapad 110S-11IBR Touchpad Replacement: passo 5, imagem 2 %32
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Touchpad Replacement, Touchpad: passo 6, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove four 2.7 mm screws from the touch pad clicker assembly.
  7. Lenovo Ideapad 110S-11IBR Touchpad Replacement: passo 7, imagem 1 %32
    • Remove the clicker assembly.
  8. Lenovo Ideapad 110S-11IBR Touchpad Replacement: passo 8, imagem 1 %32 Lenovo Ideapad 110S-11IBR Touchpad Replacement: passo 8, imagem 2 %32
    • Use a plastic opening tool to remove the touch pad.
    • Time must be taken to work the adhesive without causing damage to the touch pad.
Conclusão
Samaa Aldar
Membro desde: 04/06/19
181 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S11-G11, Wilson Spring 2019 Membro de IUPUI, Team S11-G11, Wilson Spring 2019
IUPUI-WILSON-S19S11G11
Membros da 2
Autoria de 6 guias
Um comentário
i appreciate the tear down. I would like to see the screws that came out of the holes instead of empty screw holes though.
daldal - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 24
Duração total: 1,287
