Ir para o conteúdo principal
Lenovo Ideapad 110S-11IBR Battery Replacement
O que você precisa
  1. Lenovo Ideapad 110S-11IBR Battery Replacement, Battery: passo 1, imagem 1 %32
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Battery Replacement: passo 2, imagem 1 %32 Lenovo Ideapad 110S-11IBR Battery Replacement: passo 2, imagem 2 %32
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Battery Replacement: passo 3, imagem 1 %32 Lenovo Ideapad 110S-11IBR Battery Replacement: passo 3, imagem 2 %32
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Battery Replacement: passo 4, imagem 1 %32
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Battery Replacement: passo 5, imagem 1 %32 Lenovo Ideapad 110S-11IBR Battery Replacement: passo 5, imagem 2 %32
    • Lift the battery up and out of the device.
Conclusão
8 outras pessoas executaram este guia.
Um comentário
Great instructions but where can you by a replacement battery? I can’t find one anywhere.
Mark Thompson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 12
Últimos 30 dias: 40
Duração total: 7,891
