Ir para o conteúdo principal
Lenovo IdeaTab S6000 Vibration Motor Replacement
O que você precisa
  1. Lenovo IdeaTab S6000 Vibration Motor Replacement, Battery: passo 1, imagem 1 %32
    • Remove the speaker screens by working them loose with a plastic opening tool. You may need to first loosen them with tweezers or a craft knife.
    • These screens are held in place by glue that is hard to remove. Please take your time to ensure that that this step is done correctly.
  2. Lenovo IdeaTab S6000 Vibration Motor Replacement: passo 2, imagem 1 %32
    • Remove the screws from both of the spots that were covered.
  3. Lenovo IdeaTab S6000 Vibration Motor Replacement: passo 3, imagem 1 %32
    • DO NOT USE A METAL TOOL FOR THIS.
    • Go all around the casing, prying the screen away from the backing with the spudger.
    • It will make a popping sound each time one of the lock tabs is disconnected.
    • Take your time as you move all around the device when prying the backing off.
  4. Lenovo IdeaTab S6000 Vibration Motor Replacement: passo 4, imagem 1 %32
    • Pull off the plastic that is covering the battery cable.
  5. Lenovo IdeaTab S6000 Vibration Motor Replacement: passo 5, imagem 1 %32 Lenovo IdeaTab S6000 Vibration Motor Replacement: passo 5, imagem 2 %32
    • Using either the plastic opening tool or your fingers, gently pull on both sides of the plug to release it.
  6. Lenovo IdeaTab S6000 Vibration Motor Replacement: passo 6, imagem 1 %32
    • Remove the battery by grabbing the tab shown and pulling up.
    • The battery is held to the device by adhesive. Pull the battery up from the tab and it will lift out with a bit of effort.
  7. Lenovo IdeaTab S6000 Vibration Motor Replacement, Vibration Motor: passo 7, imagem 1 %32
    • Use the spudger to pry up the vibration motor.
Conclusão
Gabriel Delgado
Membro desde: 09/22/14
247 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 10-4, Brown Fall 2014 Membro de USF Tampa, Team 10-4, Brown Fall 2014
USFT-BROWN-F14S10G4
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 10
Duração total: 967
