Ir para o conteúdo principal
Lenovo IdeaTab S2109A-F System Board Replacement
O que você precisa
  1. Lenovo IdeaTab S2109A-F System Board Replacement, Battery: passo 1, imagem 1 %32 Lenovo IdeaTab S2109A-F System Board Replacement, Battery: passo 1, imagem 2 %32
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F System Board Replacement: passo 2, imagem 1 %32 Lenovo IdeaTab S2109A-F System Board Replacement: passo 2, imagem 2 %32
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F System Board Replacement: passo 3, imagem 1 %32
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
  4. Lenovo IdeaTab S2109A-F System Board Replacement, Unscrewing the System Board: passo 4, imagem 1 %32 Lenovo IdeaTab S2109A-F System Board Replacement, Unscrewing the System Board: passo 4, imagem 2 %32
    • Locate the long, L-shaped system board; copper foil runs most of its length.
    • Remove the 10 2mm PH00 black screws located on the edges of the system board using a PH00 Screwdriver.
  5. Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the First Connection to the System Board: passo 5, imagem 1 %32
    • First Disconnect the gold connector by lifting the latch on it up and pulling it loose using the latch to pull.
  6. Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the next three connections of the System Board: passo 6, imagem 1 %32 Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the next three connections of the System Board: passo 6, imagem 2 %32
    • As you lift the board up you will notice two more connections, one near the power switch and one on the I/O Panel.
    • Remove each one with a minimal amount of upward pulling force as you flip the board over.
  7. Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the final connector of the System Board.: passo 7, imagem 1 %32 Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the final connector of the System Board.: passo 7, imagem 2 %32 Lenovo IdeaTab S2109A-F System Board Replacement, Disconnecting the final connector of the System Board.: passo 7, imagem 3 %32
    • To disconnect the system board there is one last connection.
    • Lift up the back latch on this connection and the orange ribbon should slide right out without any effort thus disconnecting the board.
Conclusão
Timothy
Membro desde: 01/30/15
301 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 17-3, Watkins Winter 2015 Membro de USF Tampa, Team 17-3, Watkins Winter 2015
USFT-WATKINS-W15S17G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 501
