Ir para o conteúdo principal
Lenovo IdeaTab S2109A-F Battery Replacement
O que você precisa
  1. Lenovo IdeaTab S2109A-F Battery Replacement, Battery: passo 1, imagem 1 %32 Lenovo IdeaTab S2109A-F Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Battery Replacement: passo 2, imagem 1 %32 Lenovo IdeaTab S2109A-F Battery Replacement: passo 2, imagem 2 %32
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Battery Replacement: passo 3, imagem 1 %32
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Caelen
Membro desde: 01/16/15
228 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 17-3, Watkins Winter 2015 Membro de USF Tampa, Team 17-3, Watkins Winter 2015
USFT-WATKINS-W15S17G3
Membros da 4
Autoria de 10 guias
2 comentários
Folks this is not easy! The first thing that happened, my screen broke. Then it took about thirty minutes to finally get the back off and the on-off swithch was damaged. Take it to a shop and let them do the damage, then its up to them to pay for it or replace it. I’m now out a s2109 Lenovo tablet because the instructions said easy. Maybe his was. This one sure as heck was not!!
jangoodman - Responder
Theres some screws missing from the directions, under the speakers and in a hole along one side. Tiny torx on the side.
Devin Holland - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 15
Duração total: 1,544
