Ir para o conteúdo principal
Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement
O que você precisa
  1. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, Battery: passo 1, imagem 1 %32
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 2, imagem 1 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 2, imagem 2 %32
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 3, imagem 1 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 4, imagem 1 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 4, imagem 2 %32
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 5, imagem 1 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 5, imagem 2 %32
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
  6. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, System Board: passo 6, imagem 1 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, System Board: passo 6, imagem 2 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, System Board: passo 6, imagem 3 %32
    • Remove three silver 1.8 mm Phillips #00 screws.
  7. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 7, imagem 1 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 7, imagem 2 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 7, imagem 3 %32
    Comprar
    • Use tweezers to flip up the small black plastic locks on all four connections.
    • Carefully remove each of the exposed ribbons.
  8. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 8, imagem 1 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 8, imagem 2 %32
    • Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
  9. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 9, imagem 1 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 9, imagem 2 %32
    • Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
  10. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 10, imagem 1 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 10, imagem 2 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 10, imagem 3 %32
    • Disconnect the HDMI connection with the system board
    • Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free.
    • Slide out the system board from its housing tab on the upper right corner.
    • Pull the board slowly away from the tab, and it will pop out.
  11. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement, WIFI/GPS Antenna: passo 11, imagem 1 %32
    • Once the system board has been removed, you can access the WIFI/GPS antenna.
  12. Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 12, imagem 1 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 12, imagem 2 %32 Lenovo IdeaTab A2109 WIFI/GPS Antenna Replacement: passo 12, imagem 3 %32
    • Insert the blue prying tool at the corner of the antenna. Pry up slowly, and move it across the antenna.
    • There is an adhesive holding the antenna in place, so it may take a little bit of force and movement to take off the antenna.
    • The antenna falls out easily once fully pried out.
Conclusão
Bcohen
Membro desde: 04/14/14
436 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-19, Regan Spring 2014 Membro de Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 3,386
