Ir para o conteúdo principal
Lenovo IdeaTab A2109 Digital Board Replacement
O que você precisa
  1. Lenovo IdeaTab A2109 Digital Board Replacement, Digital Board: passo 1, imagem 1 %32
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller plastic cover that runs across the top of the device.
    • Wedge the blue opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Digital Board Replacement: passo 2, imagem 1 %32 Lenovo IdeaTab A2109 Digital Board Replacement: passo 2, imagem 2 %32
    • Remove the following two screws:
    • M3.0 x 3.0 mm #00 phillips screws (black)
  3. Lenovo IdeaTab A2109 Digital Board Replacement: passo 3, imagem 1 %32 Lenovo IdeaTab A2109 Digital Board Replacement: passo 3, imagem 2 %32 Lenovo IdeaTab A2109 Digital Board Replacement: passo 3, imagem 3 %32
    • Once it is unscrewed, remove the rear cover
    • This may take a little force to get off but with enough force it should pop right off
    • Use a blue opening tool to pry it open
    • Slide the tool to one corner then grab another tool and slide it to the opposite corner
    • Pull the cover up and it will come off
  4. Lenovo IdeaTab A2109 Digital Board Replacement: passo 4, imagem 1 %32 Lenovo IdeaTab A2109 Digital Board Replacement: passo 4, imagem 2 %32
    • Use the tweezer tool to flip up the three small plastic locks attached to the digital board.
    • Then, slide newly exposed ribbons out.
  5. Lenovo IdeaTab A2109 Digital Board Replacement: passo 5, imagem 1 %32 Lenovo IdeaTab A2109 Digital Board Replacement: passo 5, imagem 2 %32
    • M5.3 x 1.75 mm #00 phillips screws (silver)
  6. Lenovo IdeaTab A2109 Digital Board Replacement: passo 6, imagem 1 %32
    • Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
Conclusão
4 outras pessoas executaram este guia.
Brian
Membro desde: 04/22/14
565 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-19, Regan Spring 2014 Membro de Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 13
Duração total: 3,038
