Ir para o conteúdo principal
Introdução
Use this guide to replace the front and rear cameras.
  1. Look at the back of the tablet and locate the speakers on top of the rear cover.
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • Locate the small indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool in this indentation, under the middle of the cover as shown.
    • Pry up and push to remove the cover.
  2. Remove the following two screws: M3.0 x 3.0 mm #00 phillips screws (black)
    • Remove the following two screws:
    • M3.0 x 3.0 mm #00 phillips screws (black)
  3. Pry open the front and rear faces using a plastic opening tool. It may take a little force to separate the front and rear faces of the device. Slide the plastic opening tool to one corner.
    • Pry open the front and rear faces using a plastic opening tool.
    • It may take a little force to separate the front and rear faces of the device.
    • Slide the plastic opening tool to one corner.
    • Place another plastic opening tool into the gap and slide it to the opposite corner as shown.
    • Pull the rear cover up and back to separate it from front face of the device.
  4. Slide the rear camera ribbon from the system board.
    • Slide the rear camera ribbon from the system board.
    • Pull up on the black plastic lock on the system board for the front camera and slide the ribbon out.
    • Now, you are ready to remove the front and rear facing cameras.
Conclusão
Uma outra pessoa concluiu este guia.
Abigail Bertholf
Membro desde: 14/04/2014
521 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 7-19, Regan Spring 2014 Membro de Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Membros
14 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 489
