Ir para o conteúdo principal
Lenovo IdeaTab A2109 Battery Replacement
O que você precisa
  1. Lenovo IdeaTab A2109 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
    I just want to find out if my sd card is stuck inside how do I remove it without damaging the tablet.
    Tom Mukotora - Responder
  2. Lenovo IdeaTab A2109 Battery Replacement: passo 2, imagem 1 %32 Lenovo IdeaTab A2109 Battery Replacement: passo 2, imagem 2 %32
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 Battery Replacement: passo 3, imagem 1 %32 Lenovo IdeaTab A2109 Battery Replacement: passo 3, imagem 2 %32
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 Battery Replacement: passo 4, imagem 1 %32 Lenovo IdeaTab A2109 Battery Replacement: passo 4, imagem 2 %32
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 Battery Replacement: passo 5, imagem 1 %32 Lenovo IdeaTab A2109 Battery Replacement: passo 5, imagem 2 %32
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
    Fantastic advice. After being told by Lenovo I needed to shell out £110 for a new mobo when it just had a charging socket issue I took it upon myself to see if I could fix it. This website helped take it apart and I found that the charging socket is just a micro daughter-board.
    If you have a problem with charging then go to http://www.replacebase.co.uk and search for Lenovo A2109A. They have all the parts.
    I replaced the daughter board and battery for about £10 incl del. Parts arrived yesterday and I have fitted. Works a treat. Not sure what amazes me the most, the low cost of the parts and excellent service by replacebase or the fact Lenovo tried to rip me off.
    These instructions are spot on.
    Well done
    Goon'
    Andy Blunn - Responder
Conclusão
9 outras pessoas executaram este guia.
Kyle
Membro desde: 04/22/14
581 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-19, Regan Spring 2014 Membro de Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
Membros da 4
Autoria de 15 guias
Um comentário
If there is an SD Micro memory card installed, REMOVE IT!, before the back cover. Otherwise, the card reader/writer will be damaged.
FilAm Harley - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 9
Duração total: 8,265
