Ir para o conteúdo principal
Lenovo IdeaTab A2109 Battery Replacement
O que você precisa
  1. Lenovo IdeaTab A2109 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Battery Replacement: passo 2, imagem 1 %32 Lenovo IdeaTab A2109 Battery Replacement: passo 2, imagem 2 %32
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 Battery Replacement: passo 3, imagem 1 %32 Lenovo IdeaTab A2109 Battery Replacement: passo 3, imagem 2 %32
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 Battery Replacement: passo 4, imagem 1 %32 Lenovo IdeaTab A2109 Battery Replacement: passo 4, imagem 2 %32
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 Battery Replacement: passo 5, imagem 1 %32 Lenovo IdeaTab A2109 Battery Replacement: passo 5, imagem 2 %32
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
Conclusão
9 outras pessoas executaram este guia.
Kyle
Membro desde: 04/22/14
581 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-19, Regan Spring 2014 Membro de Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
Membros da 4
Autoria de 15 guias
Um comentário
If there is an SD Micro memory card installed, REMOVE IT!, before the back cover. Otherwise, the card reader/writer will be damaged.
FilAm Harley - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 16
Duração total: 8,273
