Ir para o conteúdo principal
Lenovo IdeaTab A1000L Battery Replacement
O que você precisa
  1. Lenovo IdeaTab A1000L Battery Replacement, Battery: passo 1, imagem 1 %32 Lenovo IdeaTab A1000L Battery Replacement, Battery: passo 1, imagem 2 %32 Lenovo IdeaTab A1000L Battery Replacement, Battery: passo 1, imagem 3 %32
    • Be sure to power off your device before taking it apart.
    • Locate the small tab, marked with the lock symbol on the upper right hand of your IdeaTab above the volume control buttons. Use your fingernail to gently loosen this tab.
    • Use your Phillips #000 screwdriver and remove the 3.5mm screw and put it aside.
    • Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting by where the screw was.
  2. Lenovo IdeaTab A1000L Battery Replacement: passo 2, imagem 1 %32 Lenovo IdeaTab A1000L Battery Replacement: passo 2, imagem 2 %32 Lenovo IdeaTab A1000L Battery Replacement: passo 2, imagem 3 %32
    • Locate the black back plate, above the battery.
    • Using a Phillips #000 screwdriver remove the 7 silver 3.5mm screws from the back plate.
    • Next, with the same screwdriver, remove the black 4.1mm screw.
    • Gently remove the back plate from the device.
  3. Lenovo IdeaTab A1000L Battery Replacement: passo 3, imagem 1 %32 Lenovo IdeaTab A1000L Battery Replacement: passo 3, imagem 2 %32 Lenovo IdeaTab A1000L Battery Replacement: passo 3, imagem 3 %32
    • Use the plastic opening tool to disconnect the battery wires from the system board. Slide your opening tool under the white plastic piece and pry it up.
    • Again, use the plastic opening tool to loosen the battery from the device by lifting up on the battery on all sides. This will detach the battery from the adhesive.
    • Gently place the battery aside.
Conclusão
10 outras pessoas executaram este guia.
Peter Newell
Membro desde: 04/15/14
627 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-21, Regan Spring 2014 Membro de Cal Poly, Team 7-21, Regan Spring 2014
CPSU-REGAN-S14S7G21
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Duração total: 22,950
