Ir para o conteúdo principal
Lenovo IdeaTab A1000L Audio Jack Replacement
O que você precisa
  1. Lenovo IdeaTab A1000L Audio Jack Replacement, Battery: passo 1, imagem 1 %32 Lenovo IdeaTab A1000L Audio Jack Replacement, Battery: passo 1, imagem 2 %32 Lenovo IdeaTab A1000L Audio Jack Replacement, Battery: passo 1, imagem 3 %32
    • Be sure to power off your device before taking it apart.
    • Locate the small tab, marked with the lock symbol on the upper right hand of your IdeaTab above the volume control buttons. Use your fingernail to gently loosen this tab.
    • Use your Phillips #000 screwdriver and remove the 3.5mm screw and put it aside.
    • Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting by where the screw was.
  2. Lenovo IdeaTab A1000L Audio Jack Replacement: passo 2, imagem 1 %32 Lenovo IdeaTab A1000L Audio Jack Replacement: passo 2, imagem 2 %32 Lenovo IdeaTab A1000L Audio Jack Replacement: passo 2, imagem 3 %32
    • Locate the black back plate, above the battery.
    • Using a Phillips #000 screwdriver remove the 7 silver 3.5mm screws from the back plate.
    • Next, with the same screwdriver, remove the black 4.1mm screw.
    • Gently remove the back plate from the device.
  3. Lenovo IdeaTab A1000L Audio Jack Replacement: passo 3, imagem 1 %32 Lenovo IdeaTab A1000L Audio Jack Replacement: passo 3, imagem 2 %32 Lenovo IdeaTab A1000L Audio Jack Replacement: passo 3, imagem 3 %32
    • Use the plastic opening tool to disconnect the battery wires from the system board. Slide your opening tool under the white plastic piece and pry it up.
    • Again, use the plastic opening tool to loosen the battery from the device by lifting up on the battery on all sides. This will detach the battery from the adhesive.
    • Gently place the battery aside.
  4. Lenovo IdeaTab A1000L Audio Jack Replacement, Audio Jack: passo 4, imagem 1 %32
    • Locate the volume button mechanism.
    • The volume button mechanism is called an FPC, it is adhered to the device frame. Remove it by prying it off using a tweezer or plastic opening tool.
    • Remove the FPC to the left of the volume button mechanism the same way.
  5. Lenovo IdeaTab A1000L Audio Jack Replacement: passo 5, imagem 1 %32
    • Locate the power button mechanism.
    • Remove the power button mechanism by prying it off using a tweezer or plastic opening tool.
  6. Lenovo IdeaTab A1000L Audio Jack Replacement: passo 6, imagem 1 %32 Lenovo IdeaTab A1000L Audio Jack Replacement: passo 6, imagem 2 %32
    • Remove the circular motor unit by gently pulling up on it using a tweezer.
  7. Lenovo IdeaTab A1000L Audio Jack Replacement: passo 7, imagem 1 %32 Lenovo IdeaTab A1000L Audio Jack Replacement: passo 7, imagem 2 %32 Lenovo IdeaTab A1000L Audio Jack Replacement: passo 7, imagem 3 %32
    • Locate the component with a QR code printed on it.
    • To disconnect this component you must first detach it from the white connector.
    • To detach it from the connector, use a tweezer to gently rotate the black piece 90 degrees so it is pointing up.
    • The white connector may have a yellow mylar sticker over it. Peel off the sticker and continue.
    • Once the black piece is pointing up the orange wires can be removed from the connectors. Using a tweezer pull the orange wires horizontally outwards from the white connector.
  8. Lenovo IdeaTab A1000L Audio Jack Replacement: passo 8, imagem 1 %32 Lenovo IdeaTab A1000L Audio Jack Replacement: passo 8, imagem 2 %32 Lenovo IdeaTab A1000L Audio Jack Replacement: passo 8, imagem 3 %32
    • Locate the orange cable to the right of the battery tray.
    • To disconnect this component you must first detach it from the white connector. Using a tweezer, pry the black piece upwards and rotate it 90 degrees so it points up.
    • There may be a yellow mylar sticker on top of the white connector. Peel off the sticker and continue.
    • Once the black piece is pointing up the orange wires can be removed from the connectors. Using a tweezer pull the orange wire horizontally outwards from the white connector.
  9. Lenovo IdeaTab A1000L Audio Jack Replacement: passo 9, imagem 1 %32
    • Using a #000 Phillips screwdriver, remove the two M1.4 3.5mm screws from the system board and set them aside.
  10. Lenovo IdeaTab A1000L Audio Jack Replacement: passo 10, imagem 1 %32 Lenovo IdeaTab A1000L Audio Jack Replacement: passo 10, imagem 2 %32 Lenovo IdeaTab A1000L Audio Jack Replacement: passo 10, imagem 3 %32
    • Locate the audio assembly near the top-right of the device.
    • Remove the audio assembly by inserting the tweezers in the circular hole in the black plastic box and pulling upwards.
    • Set the component aside and you are finished.
Conclusão
Lauren Pluim
Membro desde: 04/22/14
428 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 7-21, Regan Spring 2014 Membro de Cal Poly, Team 7-21, Regan Spring 2014
CPSU-REGAN-S14S7G21
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 1,262
