Ir para o conteúdo principal
Lenovo IdeaPad Z570 Charging Port Replacement
O que você precisa
  1. Lenovo IdeaPad Z570 Charging Port Replacement, Battery: passo 1, imagem 1 %32
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Charging Port Replacement: passo 2, imagem 1 %32
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Charging Port Replacement: passo 3, imagem 1 %32
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Charging Port Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 4, imagem 2 %32
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Charging Port Replacement, Disc Drive: passo 5, imagem 1 %32
    • Place the laptop face down with the battery slot facing away from you.
  6. Lenovo IdeaPad Z570 Charging Port Replacement: passo 6, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 6, imagem 2 %32
    • Loosen all seven 3mm screws from the back panel using a Phillips #0 screwdriver.
    • These screws cannot be removed from the device.
    • Remove the back panel from the device.
  7. Lenovo IdeaPad Z570 Charging Port Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 7, imagem 2 %32
    • Remove the 3 mm Phillips #0 screw located on the left hand side that holds the disc drive in place.
  8. Lenovo IdeaPad Z570 Charging Port Replacement: passo 8, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 8, imagem 2 %32
    • Gently remove the disc drive from the left hand side of the laptop.
  9. Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: passo 9, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: passo 9, imagem 2 %32 Lenovo IdeaPad Z570 Charging Port Replacement, Keyboard: passo 9, imagem 3 %32
    • Remove the three 12mm screws found near these symbols with a Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Charging Port Replacement: passo 10, imagem 1 %32
    • Orient the laptop at a 90 degree angle with the keyboard being vertical and the screen horizontal to the surface you are working on.
  11. Lenovo IdeaPad Z570 Charging Port Replacement: passo 11, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 11, imagem 2 %32
    • Pry the keyboard off staring from the corner where the “esc”” key is located using an opening tool.
    • Now orient the laptop in the standard position and take off the keyboard.
  12. Lenovo IdeaPad Z570 Charging Port Replacement: passo 12, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 12, imagem 2 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 12, imagem 3 %32
    • At the terminal block, flip the black switch on the terminal up.
  13. Lenovo IdeaPad Z570 Charging Port Replacement: passo 13, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 13, imagem 2 %32
    • Pull the keyboard out from the terminal block.
  14. Lenovo IdeaPad Z570 Charging Port Replacement, Charging Port: passo 14, imagem 1 %32
    • Place the laptop on the backside with the battery facing away from you.
    • Remove the eleven 7 mm screws located around the edge of the backside of the laptop using the Phillips #0 screwdriver.
  15. Lenovo IdeaPad Z570 Charging Port Replacement: passo 15, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 15, imagem 2 %32
    • Remove the two 3 mm screws located in the battery slot using the Phillips #0 screwdriver.
    • Orientate the laptop back to its original position.
  16. Lenovo IdeaPad Z570 Charging Port Replacement: passo 16, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 16, imagem 2 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 16, imagem 3 %32
    • There are three connection strips similar to the one in guide three.
    • Remove the three connection strips in the same manner as the keyboard replacement guide.
  17. Lenovo IdeaPad Z570 Charging Port Replacement: passo 17, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 17, imagem 2 %32
    • Remove the two 7mm screws found on the right side of the silver plating on the laptop using the Phillips #0 screwdriver.
  18. Lenovo IdeaPad Z570 Charging Port Replacement: passo 18, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 18, imagem 2 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 18, imagem 3 %32
    • Wedge the opening tool between the ethernet jack and the speaker to pry of the front plate of the laptop.
  19. Lenovo IdeaPad Z570 Charging Port Replacement: passo 19, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 19, imagem 2 %32
    • Remove the one 7 mm screw located at the top left corner of the laptop near the charging port using the Phillips #0 screwdriver.
  20. Lenovo IdeaPad Z570 Charging Port Replacement: passo 20, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 20, imagem 2 %32
    • There are two connection terminals on the upper right hand corner of the fan.
    • Remove the connection terminal marked with a blue stripe.
  21. Lenovo IdeaPad Z570 Charging Port Replacement: passo 21, imagem 1 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 21, imagem 2 %32 Lenovo IdeaPad Z570 Charging Port Replacement: passo 21, imagem 3 %32
    • Lift the metal plate enough to wedge your index finger and thumb to grip the charger port.
    • Remove the charging port from the device.
Conclusão
Mya DeSantos
Membro desde: 03/18/19
318 Reputação
Autoria de 2 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 35
Duração total: 1,655
