Ir para o conteúdo principal
Lenovo IdeaPad Yoga 11S Trackpad Replacement
O que você precisa
  1. Lenovo IdeaPad Yoga 11S Trackpad Replacement, Top Assembly: passo 1, imagem 1 %32 Lenovo IdeaPad Yoga 11S Trackpad Replacement, Top Assembly: passo 1, imagem 2 %32 Lenovo IdeaPad Yoga 11S Trackpad Replacement, Top Assembly: passo 1, imagem 3 %32
    • Remember to power off the device before removing any parts.
    • Position the laptop so that the bottom enclosure is facing upward.
    • Use a Phillips #0 Screwdriver to remove the ten 1.9mm screws holding the bottom enclosure in place.
    • Use an opening tool to carefully pry up the rubber pads.
    • Use a Phillips screwdriver to remove the two screws under the rubber pads, which secure the keyboard.
  2. Lenovo IdeaPad Yoga 11S Trackpad Replacement, Remove Keyboard: passo 2, imagem 1 %32
    • Flip the laptop over and swing open the display.
    • Lift the edge of the keyboard closest to the trackpad up.
    • Carefully disconnect keyboard ribbon cable from the laptop.
    • Remove the keyboard.
  3. Lenovo IdeaPad Yoga 11S Trackpad Replacement: passo 3, imagem 1 %32
    • Remove the two screws securing the midframe.
  4. Lenovo IdeaPad Yoga 11S Trackpad Replacement: passo 4, imagem 1 %32 Lenovo IdeaPad Yoga 11S Trackpad Replacement: passo 4, imagem 2 %32 Lenovo IdeaPad Yoga 11S Trackpad Replacement: passo 4, imagem 3 %32
    • Grab the front edge of the top assembly and lift it up carefully.
    • There are three ribbon cables that attach the top assembly to the motherboard. Lift carefully to avoid damaging them.
    • Gently slide the three ribbon cables out of their slots.
    • Remove the top assembly completely by pulling it off of the device.
  5. Lenovo IdeaPad Yoga 11S Trackpad Replacement, Trackpad: passo 5, imagem 1 %32 Lenovo IdeaPad Yoga 11S Trackpad Replacement, Trackpad: passo 5, imagem 2 %32
    • Position the removed top encasing where it sits on the keyboard and trackpad. The inside of the top encasing should be upward facing.
    • Use a plastic opening tool to lift the retaining flap to disconnect the ZIF connector.
    • Gently pull the trackpad cable out of the socket.
  6. Lenovo IdeaPad Yoga 11S Trackpad Replacement: passo 6, imagem 1 %32
    • Locate the four 1.6mm screws that connect the trackpad to the top housing.
    • Use a Phillips #00 Screwdriver to remove the screws.
  7. Lenovo IdeaPad Yoga 11S Trackpad Replacement: passo 7, imagem 1 %32
    • Flip the top assembly over so the keyboard is on top.
    • Gently push the trackpad out of its position.
Conclusão
Uma outra pessoa concluiu este guia.
Landon Epps
Membro desde: 03/26/15
982 Reputação
Autoria de 5 guias
Equipe
Baylor, Team 7-11, Williams Spring 2015 Membro de Baylor, Team 7-11, Williams Spring 2015
BU-WILLIAMS-S15S7G11
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 3,992
