Ir para o conteúdo principal
Lenovo IdeaPad Y580-2099 Speaker Replacement
O que você precisa
  1. Lenovo IdeaPad Y580-2099 Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Slide out both locks for the battery, located on the back of the device.
  2. Lenovo IdeaPad Y580-2099 Speaker Replacement: passo 2, imagem 1 %32 Lenovo IdeaPad Y580-2099 Speaker Replacement: passo 2, imagem 2 %32
    • Remove the battery.
  3. Lenovo IdeaPad Y580-2099 Speaker Replacement, Keyboard: passo 3, imagem 1 %32 Lenovo IdeaPad Y580-2099 Speaker Replacement, Keyboard: passo 3, imagem 2 %32
    • Unscrew the 2 screws on the bottom of the device.
    • Slide the back panel out.
  4. Lenovo IdeaPad Y580-2099 Speaker Replacement: passo 4, imagem 1 %32
    • Unscrew the 3 "keyboard" detected screws.
  5. Lenovo IdeaPad Y580-2099 Speaker Replacement: passo 5, imagem 1 %32 Lenovo IdeaPad Y580-2099 Speaker Replacement: passo 5, imagem 2 %32
    • Flip the laptop over and open up.
    • Then pry up the whole keyboard using the spudger.
    • Make sure to use a plastic spudger. You could damage the device using anything else.
    • Make sure not to take the frame that goes around the keys off. This part is not removable.
  6. Lenovo IdeaPad Y580-2099 Speaker Replacement, Motherboard: passo 6, imagem 1 %32 Lenovo IdeaPad Y580-2099 Speaker Replacement, Motherboard: passo 6, imagem 2 %32 Lenovo IdeaPad Y580-2099 Speaker Replacement, Motherboard: passo 6, imagem 3 %32
    • Flip laptop back over and unscrew the disc drive screw.
    • Remove the disc drive.
    • Unscrew all of the screws on the back of the device.
  7. Lenovo IdeaPad Y580-2099 Speaker Replacement: passo 7, imagem 1 %32 Lenovo IdeaPad Y580-2099 Speaker Replacement: passo 7, imagem 2 %32 Lenovo IdeaPad Y580-2099 Speaker Replacement: passo 7, imagem 3 %32
    • Flip the device over.
    • Unplug the two wires, as shown in the images.
    • Lift up on the keyboard bezel.
    • The bezel should come up easy, if not go back and make sure all screws have been removed.
  8. Lenovo IdeaPad Y580-2099 Speaker Replacement: passo 8, imagem 1 %32 Lenovo IdeaPad Y580-2099 Speaker Replacement: passo 8, imagem 2 %32
    • Unscrew the screws on the motherboard.
    • Disconnect the three connectors the two black and one white.
  9. Lenovo IdeaPad Y580-2099 Speaker Replacement: passo 9, imagem 1 %32
    • Carefully lift up the motherboard.
    • Unplug the wires underneath the motherboard.
    • Be careful not to rip the wires underneath the motherboard while lifting it up.
  10. Lenovo IdeaPad Y580-2099 Speaker Replacement, Speakers: passo 10, imagem 1 %32 Lenovo IdeaPad Y580-2099 Speaker Replacement, Speakers: passo 10, imagem 2 %32
    • Unscrew the two screws in each of the corners of the speakers.
    • Remove the speakers.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 1,442
